Is there a config option to set to not display shadows on a transparent floor with the new Creo realtime rendering ?
In options>model display under real time rendering settings you have "Enable shadows cast from model onto specific room walls".
Uncheck it and you will lose shadows,
Thank you fo your answer. I have already found this entry in the options tabs.
I would like to know if there is an item in the config.pro (hidden or not) to set this by default (not enable shadows cast from model onto specific room walls).
l have found only:
real_time_rendering_display --- Set the realtime rendering to project shadows/reflections on a transparent floor. Default value: transparent_floor
Try to test it...
