I am having problems using the results window of Creo 3.0. In Creo 1.0 and 2.0 I was always able to zoom in on specific stress concentrations and hit "View max" to find the highest value in view.
But in Creo 3.0 that functionality appears to be broken. I can only use the "View max" when I view parts from far away. If I zoom in on something and try to use the "View max" function I always get the error message "No maximum value could be determined. The selected window is empty as currently viewed." even though the results vindow is completely filled by the part in view.
Similarly, "Dynamic query" does not return anything if the view is zoomed in. It only works when looking from a distance.
Please advice if this is a bug?
If it is a bug, then please advice if a work arround exists, e.g. if it is possible to open results from Creo 3.0 with Creo 2.0 or if there is any other way to get the functionality back?
Thank you in advance.
Hello Stig, a fix for the SPR 2875861 it will be included in Creo 3.0 M100, the SPR description is: " Using View Max in Creo Simulate results window shows information window with message No maximum value could be determined. The selected window is empty as currently viewed."
Jose
