Creo 3 Simulate Configuration to Run Within Creo Parametric?
BryanBruder
2-Guest
We are using Creo 3 and also beginning to use Simulate.  Some of our long time PTC users have asked me why Simulate is no longer embedded in Creo Parametric.  Can Creo Parametric be configured to run Creo Simulate while in Parametric?
If you want to use Creo Simulate, then simply install Creo Parametric and Creo Simulate in one step.
Then launch Creo Parametric, open part, activate Application tab and click Simulate button.
MH
Martin Hanák
Thanks Martin and Steven
Your tips prompted me to re-configure and examine my PSF files.  After re-configuring I was able to use Simulate as you documented.
My next step is to use the new PSF files and modify to use with Windchill.  Once I do this I am confident this will most likely solve my issue.
