Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\MAIN\FeatureControl\FEATURE_MAXCONNECTIONSPER1_0SERVER] "iexplore.exe"=dword:0000000a "xtop.exe"=dword:0000000a "uwgm_client.exe"=dword:0000000a ==== reg file ends on previous line =====
The last two keys require a config option: dm_network_threads <some number=" goes=" here="> Testing to find the proper number is a bit involved. Default number is 3, I use 8. You can go up to 10, but there are diminishing returns for using larger numbers. A proper test requires running Creo in debug mode and then examining the uwgm.log file. In a shell you can search for Background in the uwgm log file and get the start and finish times. <shell prompt=">findstr "Background" "<proe home=">\Log_PROE_28_05936_2011_10_17_14_36_21_000001\uwgm.log.1" 2011-10-17T21:51:28.050Z: S: uwgm.session0.1: Workspace Background loading started 2011-10-17T21:51:37.246Z: F: uwgm.session0.1: Workspace Background loading finished This would indicate the download took 9 seconds. You have to clear the files from the local cache before each download test. These are the customer support bulletins on reducing download times in linked ProE sessions This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
