I have a problem with opening saved projects. I can normaly start the program and work with it, also save a new projekt.
But when I open a stored project, the program crashes. (See error message). At my Laptop I can this projekt open, it is o.k.
I have already repeatedly reinstalled the program, also older versions. The problem was always the same.
My OS is Windows 10 Home Edition 64bit, the same is on the Laptop.
Does anyone know, what may be the cause or has anyone even this problem?
