Hello!
I am having trouble getting the software properly downloaded and running. The first time I downloaded it, it said that it was complete but the would not run (could not locate the .exe. file). So I uninstalled it and tried it again. This time the installer is stuck at 2%, where its been for hours. I have NO idea what to do.
Natasha,
on PTC Creo College Download | Thank You | PTC page you can see http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf link with instructions how to download full installation media of Creo software.
Martin Hanak
Hi Martin,
Yeah, I tried that too. That didn't work either. I've taken down the firewall and antivrus. I even downloaded data for the DVD, of course, that didn't work.
A PTC member also emailed me a different license to try but that did not work. I am not sure what the issues is. I purchased the software through JouneyED (which is where my school suggested I buy it from). They send me a link to download the software from which is where I am getting the problems...the PTC Set up is stuck at 2% when copying files.
I can't seem to get either PTC or JourneyED to send an actual copy of the software CD/DVD. I think its refund time.
Natasha,
it is not sufficient to say it does not work. Please use pictures and describe your step using more details.
For example:
1.]
I downloaded zip file from https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp
2.]
I unzipped zip file using 7-zip program and run setup.exe
... and so on
Martin Hanak
