Creo Parametric 2.0 and Windows 10
mhooker
Guten Abend,
Ich habe kürzlich meinen PC auf Windows 10 aktualisiert und aus diesem Grund kann ich in Creo Parametric 2.0 bei einem Modell nicht mehr mit dem Mausrad hinein u./od. hinaus Zoomen. Dies stellt natürlich ein großes Problem beim Arbeiten an div. Projekten dar.
Hat jemand das gleiche Problem? bzw. weiß jemand wie man das Problem beheben kann?
Good Evening,
Some weeks ago I have updated my Laptop to windows 10, and now I have the Problem that I am not able to Zoom in or out with the mouse wheel at any model. The program I am working with is Creo Parametric 2.0.
Has anybody the same problem? or has anybody an idea how to fix the problem?
Mike,
I guess that you have to create separate pen table for Creo 3.0 and modify pen thicknesses in it.
Martin Hanak
Martin Hanák
Mike,
Martin Hanak
Martin Hanák
Mike,
I agree with MartinHanak‌'s suggestion.  Creating a new Pen Table file for Creo 3.0 should help.
Please give this a try and reply back on the thread to let us know if it worked.
Amit
Thanks Martin and Amit, turns out the IT guy changed the name of the network drive at the same time as installing CREO 3.0. My config file was not being found, thus the strange printing. Once the drive letter was correctly mapped the printing returned to normal.
