Creo Parametric 2.0 will not run.
jseymour-3
Hello, when I try to run Creo 2.0 Parametric( using 2.0 because at school we use that version) it will not run. No message, no pop up, nothing comes up on my screen. I tried running as administrator, changing user permissions, and reinstalling several times but nothing will work. Please help!
Here are my computer specs:
Operating system: Windows 7 Ultimate
Processor: Core 2 Quad Q8400 2.66 GHZ (Overclock to 2.8)
Ram: 4 GB DDR3      DRAM: Frequency 559 MHZ
System type: 32-bit   (The download said it was 32/64 bit)
Graphics: NVIDIA GTX 750 TI    Core:135 MHZ       Memory:405 MHZ      Size: 2048 MB
do usual test ... add following option at the end of config.pro file.
graphics   win32_gdi
