Creo UI font size
MKT
Creo UI font size
Anyone can tell how do we change the font size of the creo UI. I mean the overall size in ribbons, model tree and all?
KenFarley
(To:MKT)
Previous discussion of similar issue:
https://community.ptc.com/t5/System-Administration/Creo-UI-Text-Size/m-p/229877#M4505
The config.pro settings I have pertaining to the UI are:
default_ui_font                 DejaVu Sans Mono
fonts_size                      small
menu_font                       Tahoma
model_tree_font                 Tahoma
popuphelp_font                  Tahoma
Hopefully this helps.
KenFarley
(To:MKT)
fonts_size                      small
menu_font                       Tahoma
MKT
(To:KenFarley)
It's working. Thankyou for the guidance
