Hi there,
in Creo's bin folder (e.g. C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin ) there is a "parametric.bat", which executes
@echo off
"C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.exe" "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.psf" %*
Is it possible to place that batch file and the corresponding "parametric.psf" anywhere else?
e.g.
C:\temp\%username%\custom-parametric.bat with
@echo off
"C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.exe" "C:\temp\%username%\custom-parametric.psf" %*
I tried it, but it did not worked so far.
I think I have it.
Instead of altering parametric.psf every time, I remove every "feature" in parametric.psf once and alter those settings via the "set" command by my start script.
set PRO_LANG=frensh
set CREOPMA_FEATURE_NAME=PROE_DesignEss (10119 10113)
set PTC_D_LICENSE_FILE=7788@my_license-server.com
<loadpoint>\Parametric\bin\parametric.bat
@Mat wrote:
Hi there,
@echo off "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.exe" "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.psf" %*
e.g.
@echo off "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.exe" "C:\temp\%username%\custom-parametric.psf" %*
my suggestion ... do not play with OOTB location of psf files. I am almost sure PTC does not support different location of these files.
Maybe you can explain what do you need to achieve and why.
Hi Martin,
the parametric.psf contains e.g. language settings, license type and server, special configurations like CEF_DEBUG_PORT and so on.
I wrote a small Dialog, where Users can choose their desired license. They also can define settings like language in their own "user-config.psf".
Mandatory settings like the license server address are stored in a company configuration file.
When the user clicks on "START CREO", all important config files get combined to "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\parametric.psf".
But unfortunately this requires write access to that folder "C:\Program Files\PTC\Creo 10.0.2.0\Parametric\bin\", which is not always granted.
Thanks for the documentation.
But it only says, that you have to call a specific psf-file according to Your license choice.
To use that (instead of my script / programm, which dynamically generates parametric.psf at every start), I would have to make a psf - file for every possible configuration (license, language, debug port, etc.).
I hoped, that PTC would at least provide some startup options.
Like:
call <loadpoint>\bin\parametric.bat PRO_LANG=frensh PTC_D_LICENSE_FILE-=7788@my_license-server.com CREOPMA_FEATURE_NAME=PROE_DesignEss (10119 10113)
Otherwise, I have to change PTC's parametric.psf at every start of Creo, which would be much more convenient if those files could be located somewhere else (e.g. a folder, where the user has write access).
Like:
let me ask a simple question...why didn't you ask PTC Support?
@MartinHanak wrote:Hi,
Unfortunately, my company's support contract does not "allow" me to contact PTC directly.
We have a contract with a PTC reseller, who sells its own "let's start creo with some options"-software.
@Mat wrote:
Hi Martin,
your note that write access to that folder ... is not always granted is little bit confusing. I do not understand why some of your user do have write access and others do not.
Silly solution:
Creo is usually installed within "C:\Program Files", which "read only" for the average user.
My IT - department does not grant "admin access" for every user. So not every user can tune those permissions themself.
FYI ... personal rules related to Creo installations on my notebook are:
I think I have it.
set PRO_LANG=frensh
