Someone know how customize Model Annotations's dimension?
i cant change the color, from format don't change the color!!!!!!
what's the configuration's line?
in CR2 I can change color & can't change font.
Attach a picture and/or model (use How to attach file when you Reply to a discussion.)
MH
