Enabling Ansys Simulatin CREO
MS_Santos
I had to format a computer, logos after configuring CREO this option that follows print is no longer enabled, before formatting the machine was normal, and same license and everything.
I guess you did not select Ansys Simulation item during installation. You have to remove current installation and do new clean installation.
dnordin
(To:MS_Santos)
MS_Santos,
2 quick things to check.
  1. Make sure the Creo Ansys Simulate option was selected at install time (is it installed),  Check for <loadpoint>\Common Files\x86e_win64\creoans
  2. Check to see if the Creo Ansys Simulate license is being activated when Creo Parametric starts (or grab the floating license per session).
Dan N.
MS_Santos
(To:dnordin)
The license is CREO as shown in the printout, I've already transferred the license but it still won't enable.
