Error given after installation of Creo 2.0 M160
WilliamLamb
8-Gravel
After installing Creo 2.0 M160 (M150 was flawless) the error prod_dcu.exe has stopped working, I seem to have cured it by doing a custom install and deselecting the option to use PTC diagnostics on each application. The installer still installs the PTC diagnostics.
Here is the XML from the event log
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-06-05T14:09:50.000000000Z" />
<EventRecordID>69799</EventRecordID>
<Channel>Application</Channel>
<Computer>MCADDELL36.dl.ac.uk</Computer>
<Security />
</System>
- <EventData>
<Data>prod_dcu.exe</Data>
<Data>0.0.0.0</Data>
<Data>5549d25c</Data>
<Data>40000015</Data>
<Data>0000000000aa4d45</Data>
<Data>2d80</Data>
<Data>01d09f99490f9832</Data>
<Data>E:\opt\ptc\Creo 2.0\Common Files\M160\x86e_win64\obj\prod_dcu.exe</Data>
<Data>875a2898-0b8c-11e5-877e-f8b156d816eb</Data>
</EventData>
</Event>
Bill,
PTC Diagnostic Tools item is always installed during installation of Creo 2.0 M150+. If you use commercial Creo license, you can uninstall PTC Diagnostic Tools when Creo installation is finished. Simply go to Programs and Features and uninstall it.
Note: I don't know the purpose of prod_dcu.exe ...
Martin Hanak
Martin Hanák
Hi Martin,
It is still installed, I just told the installer not to use the diagnostic facility using the customize function, that seems to have stopped it popping up.
prod_dcu.exe reports the following when it is run in a cmd tool
usage: pdod_dcu product [ -flag ]... -element elemValue ...
here is the offending message that shows up when you start creo parametric, pressing Close the program dismisses the box, its just annoying more than anything else
