I've had good luck with "Gaming" video cards in the past too. What's been your experiance?
The testing we have done shows that there is not much speed difference with different video cards. We have found the most change in speed from faster processors and more memory.
Eventhough PTC suggests the Quadro or FireGL cards I don't think it matters if you use a game card or not (they are much less expensive). Having the openGL drivers is absolutely required though.
We have assemblies that take 4 to 6GB of memory to open, but they run the same on a system with all the video cards we have tried on it. I can't wait for Pro/E to make use of the GPU capabilities. In theory that could speed up the system substantially.
I had a hard time following your video, so not sure I understood it.
