Creo performance advisor displays the usage of various functionality as showed in below image.
Is there any way to classify this feature as per Creo license type?
Example : 3D Print option from Below report is available in Creo Engineer -I or Creo Engineer -II license module
Any help will be much appreciated on this topic.
