Hi Chris,
I've been involved with high school students using consumer-level laptops to run Creo for several years. Most work fine for basic modeling. They start hitting a wall when pulling up mid-sized assemblies. This is even with the on-board video cards. Personally, I have a little 15" Inspiron laptop that I've been able to do quite a bit of work with Creo 2.
So, as long as it's not really a work-critical use or as long as you're not pulling up assemblies with 100's of parts or heavy complexity, you should be fine.
Worst-case scenario, running graphics under win_32gdi config.
Good luck,
Josh
Joshua Houser
(have I talked to you about FIRST robotics yet?)
Pelco by Schneider Electric
Methods & Tools Sr. Engineer
Ack! Look at you plugging your robotics event! I don't know if that's allowed here! 😉 Actually, I'm thinking about getting a Sumo competition set up here at our local maker/hackerspace.
Given the parts counts you're working with, I doubt you'll have a problem. I suspect that using Mechanism or doing much rendering might stress out the PC a bit.
Joshua Houser
