License File
ptc-643732
License File
I am using Creo Parametric Release 9.0 and Datecode9.0.0.0
The license file failed to install, see error message below. The license file has been retrieved from the PTC Support page. All license files before never caused an issue with installation.
Here are the errors that I faced
2022/05/05 10:04:44: Did not upload file - Error: A correctly-formatted VENDOR line was not found in the license file.
Hi @ptc-643732,
Are you installing license manager using Creo 9.0 installation media or updating the exiting installation of Flexnet?
You may try replacing the Server and daemon lines in new license by copying the same from old license file and rename that as license.dat. Rename the existing license.dat to something else and place the new one in licensing folder. Try restarting the service for license manager service.
I hope this will help.
Thanks.
According to this Support Article
www.ptc.com/en/support/article/CS154266
You have to have "FLEXnet 11.17.1.0 or later" installed for the Creo 8.0 and 9.0 license files. If you're running an older version of the FlexNET software, you've got to update to the latest or the license files won't work. I went through this just recently.
Hi @ptc-643732,
Did you manage to get this working?
