The current licensing failure is due to an exception thrown by the PTC JBOSS installation, I've posted the exception message below.
The underlying cause is that the licensing application is expecting a parameter "app" that Express 4.0 isn't sending when attempting to retrieve a license.
Adding a querystring parameter "app" to an HTTP request will get past the exception, but using the wrong value will provide a response of "Invalid Application". I'm unsure what value should be used.
Fails: https://support.ptc.com/appserver/securePeModeling/peAutoLic.jsp?dt=18:49:28.1020116
Succeeds with Invalid Application: https://support.ptc.com/appserver/securePeModeling/peAutoLic.jsp?dt=18:49:28.1020116&app=xx
Isaac Dover
Smyrna, GA
org.apache.jasper.JasperException: An exception occurred processing JSP page /securePeModeling/peAutoLic.jsp at line 39
36: String peWindows = (String)request.getParameter("windows"); //Windows = "" | 5.0 | 5.1 | 6.0
37:
38:
39: if (peApp.equalsIgnoreCase("3D")){
40: %>
41: <jsp:include page="cocreatePeModelling.jsp" >
42: <jsp:param name="username" value='<%=peUsername%>' />
Stacktrace:
org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:498)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:411)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:322)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java:249)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
root cause
java.lang.NullPointerException
org.apache.jsp.securePeModeling.peAutoLic_jsp._jspService(peAutoLic_jsp.java:71)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:369)
