Guru's,
Anyone else having "issues" with the results windows? I have, for what
seems like the past year of so. Some times I will run an analysis, have
converged results, and have the results window tell me "none of the
results can be displayed", or something to that effect. Other times, I
will display one result, and then try to add a second result window,
only to have ONLY one of the windows display at a time, not BOTH at the
same time which is what I want. Even if I have a .rwd file saved with
TWO windows successfully displayed, some times when I try to reload that
file, it goes into the "only showing one at a time" mode. The
maddening fix for this is to close out of WF 4 (that's what I'm using
currently, but I have seen this behavior, though not NEARLY as bad with
WF3), restart WF4, load up my model, go into Mechanica and try again,
which usually works just fine. I'm working on an HP XW8600 workstation
with 4 gig of RAM and a Nvidia Quadro FX 3700 graphics card (which I've
upgraded the driver for a couple of times...). I'm just wondering if
others have seen this behavior and if it's worth opening a call with
PTC.
thanks in advance.
Paul Korenkiewicz
FEV , Inc.
4554 Glenmeade
Auburn Hills, MI, 48326-1766
