I am using Creo Parametric Release 8.0 and Datecode8.0.5.0
In ModelCHECK, ACCURACY_INFO does not update absolute accuracy values. It does update relative values
I did . . . resulting in SPR 14464196.
Development team has fixed the issue and the fix will be available in Creo Parametric 8.0.9.0. and 9.0.5.0.
Perhaps the setup of your ModelCHECK is not taking into account that the limits are defined by different parameters depending on whether the accuracy is absolute or relative. A quick online search using "creo modelcheck accuracy_info" yields the following:
In brief, it calls for:
Thanks for the reply. Yes I did consider the limits for both Relative and Absolute
I can change the accuracy to the absolute value in the regular, manual way just not with MC
By ModelUPDATE mode, Creo ModelCHECK automatically changes the accuracy to this value if the accuracy is not within the acceptable limits.
MU_ACCURACY ABSOLUTE 0.001
Thank you for providing your comment.
ModelUPDATE mode is a bit too aggressive for me.
I want ModelCHECK to warn of unacceptable accuracy value and provide the option to change it then.
Please refer to Help Center about Check option ACCURACY_INFO:
Hope this help clarify this topic.
Thanks for the recap of the help files.
I've got a ticket in on this. 16689343
Did you get any support for your ticket? I am experiencing the same issue where updates can be made thru the model properties but changes are not applied if changed in the ModelCheck interface.
