Hello @cordeneaux ,
I suspected perhaps there might be solid geometry in your template models, and this is the reason support request was opened in the community.
I checked into this and compared Creo 4.0 behavior with Creo 10.
I observed Creo 4.0 did use the solid template as well:
Next, I created a template with solid geometry and tested
Solid geometry template image:
I then compared results using default creo template & then same part using template with soild geometry set in config.pro, and noticed a difference that I feel warrants further investigation by PTC R&D:
Given the above, I have opened a case on your behalf and will reach out offline.
Best regards,
Mark
