Does anyone have any tricks that they can share about getting EDWIN MUIRHEAD 's great license tracker utility up and running? We have it installed and it is gathering data every 10 minutes, but the data is not showing up on the webpages.
Other info:
In case you are interested in getting the software, go to : http://sourceforge.net/projects/cadmintools5/?source=directory
Woot! We got it working!!
I will have to thank Edwin for writing this, once it is working it does a great job.
The two things that seemed to be holding us up were:
The missing temp folder needed to be created under the log folder.
The missing delimiters were:
