C:\license_ptc\new_license\license_standard.txt file was probable sent to you via email. It contains Creo floating license, because it contains two special lines - SERVER and DAEMON.
C:\license_ptc\new_license\license_standard.txt file is used as license source, when you install FLEXnet license manager for the first time.
If FLEXnet license manager was installed on your PC in the past, then C:\license_ptc\new_license\license_standard.txt file can be used to update license information located in license.dat file in FLEXnet license manager installation directory. In this case you have to keep SERVER and DAEMON lines.
MH
