Note Display in Assembly Mode
dgschaefer
21-Topaz II
WF4
I have a 3D note / Annotation created in a part. I have the 'Notes'
toggle on and my 'Notes' layer in the part on.
In part mode, the note is visible as expected; however, in the assembly
I cannot get it to show. I've checked the model display settings and
the environment settings but cannot find anything that would seem to
control this.
How do I get this to show in assembly mode? Is there a config option
I'm missing?
Doug Schaefer
LinkedIn
Doug,
I'm running WF 5 but I believe the config option "visible_annotations_scope" is there as well. It lets you specify whether sub-model annotations are visible in assemblies. By default it is set to "Active Model Only" but you can set it to "All"
Give that a try - should do what you want
Mike Brattoli
Moen Incorporated
Global Strategic Development
Engineering Systems Administrator
25300 Al Moen Drive
North Olmsted, OH 44070
visible_annotations_scope all
NEW Creo+ Topics: PTC Control Center and Creo+ Portal
