OTK, PROTK. Selection in the background
amedina-2
I want to make dialog like for creating planar constraint, but can't understand how to set filters to wfcSession selection or make call wfcSession->Select(wfcSelectionOptions_ptr) in background with ActionListener like "OnSelect" or something. Can anyone help me with this issue?
creating planar constraint dialog image :http://joxi.ru/v29l1M0sgYEamG
found that if set up to choose one item than dialog hide correctly
pfcSession_ptr pSession = pfcGetProESession();
wfcWSession_ptr wSession = wfcWSession::cast(pSession);
wfcSelectionEnvironmentOptions_ptr wfcSelEnvOptions = wfcSelectionEnvironmentOptions::create();
wfcSelectionEnvironmentOption_ptr selEnvOpt = wfcSelectionEnvironmentOption::Create(wfcSELECT_HIDE_SEL_DLG, 1);
wfcSelEnvOptions->append(selEnvOpt);
wfcWSelectionOptions_ptr wSelOpt = wfcWSelectionOptions::Create(choosenType, 1, wfcSelEnvOptions);
pfcSelectionOptions_ptr pSelOpt = pfcSelectionOptions::softcast(wSelOpt);
pfcSelections_ptr pSelections =  wSession->Select(pSelOpt);
wfcSession->Select is perfect for this. What do you want to select ?
AFAIK :
1. Create an option_ptr
pfcSelectionOptions_ptr option_ptr = pfcSelectionOptions::Create("String Identifier");
Creo Parametric Database Item
String Identifier
ModelItemType
Datum point
point
pfcITEM_POINT
Datum axis
axis
pfcITEM_AXIS
Datum plane
datum
pfcITEM_SURFACE
Coordinate system datum
csys
pfcITEM_COORD_SYS
Feature
feature
pfcITEM_FEATURE
Edge (solid or datum surface)
edge
pfcITEM_EDGE
Edge (solid only)
sldedge
pfcITEM_EDGE
Edge (datum surface only)
qltedge
pfcITEM_EDGE
Datum curve
curve
pfcITEM_CURVE
Composite curve
comp_crv
pfcITEM_CURVE
Surface (solid or quilt)
surface
pfcITEM_SURFACE
Surface (solid)
sldface
pfcITEM_SURFACE
Surface (datum surface)
qltface
pfcITEM_SURFACE
Quilt
dtmqlt
pfcITEM_QUILT
Dimension
dimension
pfcITEM_DIMENSION
Reference dimension
ref_dim
pfcITEM_REF_DIMENSION
Integer parameter
ipar
pfcITEM_DIMENSION
Part
part
N/A
Part or subassembly
prt_or_asm
N/A
Assembly component model
component
N/A
Component or feature
membfeat
pfcITEM_FEATURE
Detail symbol
dtl_symbol
pfcITEM_DTL_SYM_INSTANCE
Note
any_note
pfcITEM_NOTE, pfcITEM_DTL_NOTE
Draft entity
draft_ent
pfcITEM_DTL_ENTITY
Table
dwg_table
pfcITEM_TABLE
Table cell
table_cell
pfcITEM_TABLE
Drawing view
dwg_view
N/A
2. Do your select and get back your pfcselection_ptr.
3. Undefined maxlength
int length = sel_ptr.getarraysize();
for (int i = 0; i < length; i++) {
  sel_ptr.get(i);
3. Defined maxlength
sel_ptr.get(0);
4. Cast it to the stuff you say he can select. If it's more than one you need to check the type.
Br,
Eike
PS: Code is written down without testing it ... so please check it before you run it ^.^
thanks, I tried "wfcSession->Select", but still have default dialog appears, I want to do something like Creo Simulate planar constraint dialog reference selection.
Here some code:
pfcSession_ptrpSession = pfcGetProESession();
wfcSelectionEnvironmentOption_ptr ptropt = wfcSelectionEnvironmentOption::Create(wfcSELECT_HIDE_SEL_DLG, 1);
wfcSelEnvOptions->append(ptropt);
wfcWSelectionOptions_ptr wOpt= wfcWSelectionOptions::Create("surface",-1,wfcSelEnvOptions);
pfcSelectionOptions_ptr pOpt = pfcSelectionOptions::softcast(wOpt);
wSession->Select(pOpt);
One more Idea ...
If you use the std. select and you are in a Program that is async. You need to know how the window name ist (collect it by mapkey) and it could be that you can use ProDialogHide() or something like that on it. But I don't know if it reacts after that like it should.
It could be that this isn't possible at that moment and crashes Creo ... so I don't know ... just an idea.
Or you live with the small Dialog, because it's std. PTC behaivior ^.^
Br,
Eike
thanks, I'll try ProDialogHide(), may be any ideas how to set up filters without using wSession->Select or ProSelect() ?
Pretty cool : ) Thanks for sharing
