What is the use of this "Performance monitor" command under analysis toolbar.
Thanks & Regards
Vijay.
Hi Vijay,
Here is an article, that discusses,in detail the Performance Monitor Analysis:
CS143996 - How to use Performance Monitor analysis in Creo Parametric
The article is quite lengthy, so I can't really copy the gist of it here. If you can't access the article, please create an account here, so that you can gain access to it.
Amit
