Parametric.exe *32
mheath
Parametric.exe *32
I'm curious about something and wondered if anybody had an answer to this. I am running Creo 2.0 M040 on a M6600 Precision Dell Laptop, windows 7 64bit.
When I launch Creo 2.0 and look in the Task Manager I see a "parametric.exe *32". Is Creo running 32bit or what does this represent?
[cid:image001.png@01CE2ABF.F2FCB190]
Thanks in advance,
Carpe Diem,
"Happiness equals reality minus expectations"
Michael Heath
Schlumberger Reservoir Completions
14910 Airline Rd.
Rosharon, TX 77583
Yes, it would seem that it is a 32 bit program.
TomU
(To:mheath)
Parametric.exe is 32 bit, but xtop.exe (the actual Pro/e process) is 64 bit.
[cid:image002.png@01CE2ACA.824121B0]
[cid:image003.png@01CE2ACA.824121B0]
(WF5, Creo 1, and Creo 2 all running at the same time.)
Tom U.
mheath
(To:mheath)
Anybody got any thoughts on what the parametric.exe process is. Just curious.
RandyJones
(To:mheath)
Most likely proe.exe (err parametric.exe) was born when PTC developers couldn't make a dos bat file
do what they were/are doing with a unix csh file.
Startup sequence is like this:
* Unix
1. run <proe_install_dir>/bin/proe
o csh that sets up the environment base on the platform
2. this directly calls $prodir/$mc/obj/pro $*
* Windows
1. run <proe_install_dir>/bin/proe.bat
o a bat file that does not do any setup
2. this calls <proe_install_dir>/bin/proe.exe <proe_install_dir>/bin/proe.psf
o so notice the proe.exe gets passed the proe.psf which contains "environment" variables
o this proe.exe is most likely doing what the proe csh unix script does
3. this calls <proe_install_dir>/<mach_type>/obj/xtop with appropriate enviroment and arguments
So on the Unix side the actual Pro/Engineer process is <proe_install_dir>/<mach_type>/obj/pro and on
the Windows side the actual Pro/Engineer process is PROE_INSTALL_DIR>/<mach_type>/obj/xtop.exe
> Just curious.
> Thanks,
> *From:*Uminn, Tom [
> *Subject:* RE: Parametric.exe *32
> Tom U.
> *From:*Michael Heath [
> *Subject:* [proecad] - Parametric.exe *32
> Thanks in advance,
> */Carpe Diem/**/,/*
> *"Happiness equals reality minus expectations"*
> /Michael Heath/
> /Schlumberger Reservoir Completions /
> 14910 Airline Rd.
> Rosharon, TX 77583
> E-mail: - <">mailto:->
> Phone: 281-285-7570
> Fax: 281-285-5746
> -----End Original Message-----
> ********CONFIDENTIALITY NOTICE********
> The information in this email may be confidential and/or privileged.
> This email is intended to be reviewed and used only by the individual
> or organization named above for the explicit purpose of conducting
> business with Trans-matic Mfg. Co. If you are not the intended recipient
> or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copying of this email and its attachments, if any, or the information contained herein is strictly prohibited, and no privilege or protection has been waived. If you have received this email in error, please notify the sender immediately by return email and delete this email from your system.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
