Part library Installation
msanan
I have installed the part library module (following standard installation prompts and directories) - but when I try launch it, I get the following error:
Any assistance would be greatly appreciated.
Thank you.
MaxR.Kublin
(To:msanan)
Is Modeling also V19?
If yes, you have possibly NOT installed part library but 3D Library or 2D library?
akhare
(To:msanan)
Can you please check if you have a valid registry entry for PartLibVersion under HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\CoCreate\PartLibrary\20.0 and the variable PartLibPath under HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\CoCreate\PartLibrary\20.0.0000 shows correct part of installed Part Library?
If you have installed 19.0 PL, please change 20.0 with 19.0 in above registry entries.
HTH,
Ashish Khare
MaxR.Kublin
(To:msanan)
Version of Part Library must match the version of Modeling.
Which version are you using?
Hi Max.
I'm using V19 as supplied via install media from PTC.
MaxR.Kublin
(To:msanan)
Hi Max.
That was indeed the problem. All is good now. Thank you so much for your help.
Tell me, what is the 3d library?
