When plotting to a TIFF file from a drawing, the output has changed from Wildfire 3 to WIldfire 5 (CE Pro). (Never used WF4)
In WF3, the image file was bounded by the extents of the plotted geometry.
Therefore, the smaller the image, the smaller the total image size and file size.
In WF5, the image bouldary is the entire sheet, which creates a lot of "white space" when there is no drawing format.
We would like to have it work the way it did in WF3.
Is there a config setting or PCF setting that controls this beharior?
Gerry
