I have an M6600 mobile work station and it seems like the performance/graphics settings are set very low (jagged edges). I used the nvidia control panel to overwrite the application settings to smooth out the edges, but is there a way to do this within the program itself? I am using WF5 and also I want to increase the distance before components disspear. Is there a way to disable WF5 from removing components/features when zooming out?
for what its worth ... I have FX580 and run 270.71 with WF5 M080 - it runs very sweetly considering its only 512MB.
Make sure the NVIDIA Control Panel has found ProE and is running the ProE Wildfire profile.
In WF5 turn Shade Quality and Edge Quality to Maximum for best display (View>DisplaySettings>Model Display)
Smooth Lines should control line anti-aliasing but sometimes doesnt work (View>DisplaySettings>Model Display>Edge/Line)
For additional performance control outside WF5 you can try the following within the NVIDIA Wildfire profile
1. set Power Management Mode = Prefer max performance
this stops the card trying to save power, runs it at full speed in ProE
2. set Antialiasing - Mode = Override any application settings
then Antialiasing - Setting = 8x(4xSS,2xMS)
this will give you onscreen antialiasing - works beautifully on FX580 with WF5.
Use GPU-Z for checking how much graphics memory you are using and adjust antialiasing settings to suit availability.
That's what I was looking for, thanks!
Burt,
"Make sure the NVIDIA Control Panel has found ProE and is running the ProE Wildfire profile."
I'm trying to figure what the "ProE Wildfire profile" name is in order to load it through the NVidia Control Panel. Can you give me a little more detail as to what I should be loading?
Thanks, Bob
3D Settings
Manage 3D Settings
Program Settings
PTC Pro/Engineer Wildfire
Global Settings
Base Settings
Thanks Burt!
I was missing the step: un-check the box below that says - "show only programs found on this computer".
Thanks for your help.
Bob
