Problem starting Parametric 3.0
apaltzer
Every time I try to launch the application, I get a message that states "Windows is searching for parametric.exe" and there is a Browse option, but I do not see any sort of executable file in the folder. Please help, I have homework due tomorrow!!!!!!
Alexis,
Try executing parametric.exe from <Installtion location of Creo>\Parametric\bin, it it works, you can create a shortcut of that exe.
Hi Alexis,
If Mahesh's suggestion doesn't work, then you may need to uninstall and re-install the software.  I would also recommend that, if you do have to re-install, then use the Run as administrator option.
Amit
please publish Properties dialog box related to Creo shortcut.
MH
