Hello everyone, I'm having a problem with the resolution of my video card, because the image appears normal model and a banner at the top of the screen and on the right side of the main screen of 1.0 Creo he estora the model is thus not I have more visualization of this region in the model, I wonder if you have any configuration that can improve it for the Pro-5 and it works normal, this only happens in 1.0 Creo, has something like a plugn Chamdo opem GL or something?
grateful ......
Andre,
In the older versions of Pro/E, like Wildfire 2, .stl, .stp, .igs files, etc. would not show up in the 'File, Open' list if they had a filename which included spaces, or which was longer than (I think) 32 characters.
Very frustrating!
I think it probably still applies to later versions, too.
John
I apologise, I just answered the Wrong Question!
Sorry.
OK.
Are you saying features that should show are not showing?
If this is the case, I ran into this... it has to do with "relative accuracy". This limit you to not use small features on large parts. You have to set this in config.pro and in Model properties. It is a two spet process! you cannot fix this in config.pro only.
If this is your issue, I can expand on where to fix the problem.
