Purging
DavidKhan
Purging
Hi all
i would like to know how to purge working directry so that the size doesnot grow unneccesarily.While i have selected working directry and when i give purge command in cmd it gives error.the image of the error is attached.kindly help.
Hi David,
here >> http://communities.ptc.com/message/201439#201439
you can find a lot of information about Purge command
Vladimir
Best Regards,
Vladimir Palffy
You need to add the Creo BIN path to your system path (environment variables)
(...c:\etc...)\Creo 2.0\Parametric\bin
Hi David,
Vladimir
Best Regards,
Vladimir Palffy
but the black windows flashes and then disapperas.is there any another problem?
you can create custom mapkey for purge.
Here is the video for you: http://www.youtube.com/watch?v=RHLXsWtPojc
... and/or, here is the purge makpey "pu" *(copy to your config.pro file):
mapkey pu @MAPKEY_NAMEPurge command;@MAPKEY_LABELPurge;@SYSTEMpurge;
Vladimir
Best Regards,
Vladimir Palffy
thanks. it works now.
Good job - You are Welcome
Vladimir
Best Regards,
Vladimir Palffy
