It used to be that you could remove the "Deleted" parameters with a hidden config option. It no longer seems to work. I'm on CREO 2 m180. In the fix_params.log file there are "Deleted parameters" and a list. This list corresponds back to Locked Intralink parameters that need to be deleted. I have exported these files and want to delete the parameters. How do I get them unlocked?
That option still works with Creo 3. You do have to be disconnected from Windchill (if you use that) and the parameters can't be in use - meaning referenced in any relations.
Thanks Tom for the reply. It made me look at my config.pro one more time to realize that I had an "!" in front of the line.
