All,
I am having a difficult time trying to figure out a hole table issue. When I open a sheet metal drawing, I can generate a hole table and it includes every hole in the sheet metal part. When my co-workers try this, the hole table only includes a portion of the holes. All the settings in the hole table dialog box are the same? Is there a config.pro setting that they need to change so that it selects all the holes?
Nick
Please be aware that a hole table will only display holes created on one side of the part relative to the specified coordinate system. I'm not sure if this is the issue or not since I don't know if you and your co-worker are working with the same sheet metal part. Are your co-workers creating the hole table for the exact same part or a different one?
Mark,
Thanks for the reply. We are working on the exact sheetmetal piece part, that is why we are so confused.
Nick
Nick,
see rules mentioned in Re: While creating hole table in creo, does creo only takes hole which are seen in the front view into consideration?
Martin Hanak
