Silent install for date code updates
nhanratty
2-Guest
All
Just wondering if anybody has successfully carried out a silent installation of a date code update for Creo 2.0, e.g. m050 update m120.
I can run a new installation by way of the run command and xml files technique but I'm not having the sane luck just trying to do a datecode update. Is it possible?
Neal
In my experience, a new datecode is handled as a new install.
An update is merely something to change your options (licensing choices, name) in the PSF file.
Silent isn’t something I use regardless, so I can’t help on that front.
