Some features failed to regenerate
Dom_CHENTRE
Is it possible to avoid to accept the little yellow message
"Some features failed to regenerate
Choose OK to accept or Cancel to undo the changes"
Perhaps a config.pro option ?
Maybe you're thinking of the setting:
regen_failure_handling  resolve_mode
It's the one that handles things like in the "old days" where you are forced to edit each failed feature and fix the offending aspects of them. I have it in my config.pro file, but commented out because I found it was kind of a nightmare, especially when pulling up old assemblies with "missing but unimportant" components. I only turn it on when I have a specific model I'm trying to debug.
No, there isn't a way to avoid this.  If a feature failed to regnerate, then you only have to 2 options.
Create a failed feature
OR
Undo the changes
Ok, thanks,
But I thought few versions ago, it was possible to accept (OK) by setting a config.pro option...
Not sure...
erine
(To:Dom_CHENTRE)
Notification Manager hatch_pattern_cfg_file Specifies the hatch pattern configuration file to be loaded when Creo is started.
Notification Manager nmgr_affected_by_dma Show notifications for models/features that are affected by Creo direct modifications warning, error, do_not_show, warning_with_message warning
Notification Manager nmgr_circular_references Show notification when there are circular references in the top model warning, error, do_not_show, warning_with_message warning_with_message
Notification Manager nmgr_gen_model_issues Show notifications when basic/generic model is failed warning, error, do_not_show, warning_with_message warning_with_message
Notification Manager nmgr_import_valid_issue Show notifications when import validation score is defined as passed with warning warning, error, do_not_show, warning_with_message warning_with_message
Notification Manager nmgr_modified_in_dma Show notifications for components and features whose have references have been changed since last regeneration warning, error, do_not_show, warning_with_message warning
Notification Manager nmgr_outdated_mathcad Show notifications for models that contain PTC Mathcad worksheet with values that differ from values in Creo warning, error, do_not_show, warning_with_message warning
Notification Manager nmgr_outdated_model_graphics Show notification when a model in simplified representation is outdated warning, error, do_not_show, warning_with_message warning_with_message
Notification Manager nmgr_outdated_non‐native Show notifications for non‐native models that are not up‐to‐date with respect to source warning, error, do_not_show, warning_with_message warning
Notification Manager nmgr_outdated_pdm Show notifications for models that are not up‐to‐date with recent PDM model version warning, error, do_not_show, warning_with_message warning_with_message
Notification Manager nmgr_outdated_pipe_solids Show notifications for pipe solids that are not up‐to‐ date with the recent piping application behavior warning, error, do_not_show, warning_with_message warning
Notification Manager nmgr_pending_dma Show notifications for models that were modified in Creo Direct and not reviewed. The changes should be accepted or rejected in the View Creo Changes dialog warning, error, do_not_show, warning_with_message warning_with_message
Notification Manager nmgr_ref_model_issues Show notifications when reference model is failed warning, error, do_not_show, warning_with_message warning_with_message
Notification Manager nmgr_reference_changed Show notifications for components and features whose have references have been changed since last regeneration warning, error, do_not_show, warning_with_message warning_with_message
Notification Manager nmgr_reference_out_of_session Show notifications for models/features with references not in session warning, error, do_not_show, warning_with_message do_not_show
These are all of the notification manager config options, assuming that you are on 4.0.
Creo 4.0 / M060
