Studen Edition Creo 10.
SU_10822593
Good evening,
I just wanted to download the student version of Creo 10, this also worked at the beginning. But now I have the trail version and not like my classmates the student version. Can I upgrade this in Creo or do I have to download creo again? If so, what do I have to do differently to not download the trail version.
With kind regards
Dale_Rosema
(To:SU_10822593)
Any files made in the trial version will not convert over to the education version once you get that completed.
The industrial and educational version are not compatible.
so i need to deinstall and install the creo again?
thanks for your reply
Dale_Rosema
(To:SU_10822593)
Yes. I do not know the link to the student edition, but if you are not running that currently, you will need to load that one instead.
Talk to one of your fellow students or your professor for the link to the student edition.
my suggestion ... remove trial version.
To download 5.854 GB zip installation package, use following link.
https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp
Use instructions from following documents.
https://apps.ptc.com/schools/references/install_creo10_schools_standard.pdf
-OR-
https://apps.ptc.com/schools/references/install_creo10_unistudent_standard.pdf
Create C:\PTC_install directory and unzip download zip file into it, then run setup.exe.
