This is the Best Cad software I have ever seen in my life!
I would llike to tell you Why
1. It' s better that AutoCa... because it can draw a line without command
2. It' s better that AutoCa...because it can show TOP view without clicking a button
3. It is faster than SolidW..because it can install faster
You need to go check your brain first!
Having said that parametric modelling was the original idea...in proe
N then all the big n small just copied it..
lets wait till it becomes more clear!......it might be a mine field....
Give it a month, see if you still feel the same
John
In Malaysia , I notice that Malaysian are bored using AutoCa.../SolidW../Cati... because it cannot show beautiful icons on the program like PTC Creo.
My friend in Singapore , he just bought Cati..for 42,000 USD for running his business .After installation and started the program ,he said it takes a long time,
So he changed to PTC creo , it run faster , save fast , open fast . He does not want to use other programs within 20 years from now , Only PTC creo is the best.
"beautiful icons on the program like PTC Creo"
Is this a troll-thread?
you are right...
comparing it to an incomplete software by the name of "Solidincompleteworks" or may be "SolidCopyProEworks"...
I think Most of functions in PTC creo are ORIGINAL ideas and other brands they just follow for example creating a Line
You 're right .
My teacher ever told me that PTC creo is the first program which can be able to "Save as" in thumdrive.
and I believe it , so I tried to do . Oh it is real !!
no i am serious something really wrong with your brain..just go for a check-up...don't waste any time
OK,I'll go
