Toolkit Asynchronous Application Configuration
PARTHIBAN_K
I am getting below mentioned error when trying  to create Toolkit Asynchronous example.
error LNK2019: unresolved external symbol_ProEngineerStart referenced in function_main()
I have used example file provided in toolkit installation folder → simple_async.
Anyone can help to configure t for Toolkit Asynchronous application
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
The Problem is Solved,
I missed pt_asynchronous.lib in the Linker
Parthiban Kannan
TomasLoun
(To:PARTHIBAN_K)
Are you using their 'make_simple_async' makefile?
What tool are you using for the compilation and for which Creo version?
Yes Tomas,
I am using make_simple_async
Creo Version 2.0
Visual Studio V2010
Parthiban Kannan
TomasLoun
(To:PARTHIBAN_K)
Ok, that's correct. Could you please post the whole output of the compilation? Have you made any change in the makefile?
Hi Tomas ,
I have added additional includes & now the previous problem solved but new issues created.
simple_async.cpp contains below error symbols.
Error1error LNK2019: unresolved external symbol ProTestCallReport referenced in function mainC:\TOOLKIT DEVELOPMENT\SIMPLE ASYNC\SIMPLE ASYNC\DFT\make_install\simple_async.objSimpleAsync
Error2error LNK2019: unresolved external symbol user_initialize referenced in function user_initialize_plusC:\TOOLKIT DEVELOPMENT\SIMPLE ASYNC\SIMPLE ASYNC\DFT\make_install\protk_dllmd.lib(pdp_pdevtk.obj)SimpleAsync
MAKE FILE :
# File Name
MAKEFILENAME = make_SimpleAsync
# Machine Type
PRO_MACHINE_TYPE = x86e_win64
# Executable names
EXE = SimpleAsync.exe
EXE_DLL = SimpleAsync.dll
# Pro/Toolkit Source & Machine Loadpoint  (EXTERNAL USE - DEFAULT)
PROTOOL_SRC = $(PROE_INSTALL_PATH)\protoolkit
PROTOOL_SYS = $(PROTOOL_SRC)/$(PRO_MACHINE_TYPE)
# Pro/Toolkit Source & Machine Loadpoint  (PTC INTERNAL USE)
#PROTOOL_SRC = $(PTCSRC)/protoolkit
#PROTOOL_SYS = $(PTCSYS)
# Include File Paths
INCS = -I. -I$(PROTOOL_SRC)/protk_appls/includes -I$(PROTOOL_SRC)/includes
# Compiler Flags
CC = cl
MACH = -DPRO_MACHINE=36 -DPRO_OS=4
CCFLAGS = -c -GS -fp:precise -D_WSTDIO_DEFINED
CFLAGS = $(CCFLAGS) $(INCS) $(MACH)
# Libraries
PTCLIBS = $(PROTOOL_SYS)/obj/protoolkit.lib
PTCLIBS_DLL = $(PROTOOL_SYS)/obj/protk_dll.lib
LIBS = libcmt.lib kernel32.lib user32.lib wsock32.lib advapi32.lib mpr.lib winspool.lib netapi32.lib psapi.lib gdi32.lib shell32.lib comdlg32.lib ole32.lib ws2_32.lib
# Object files
OBJS = simple_async.obj
# Linker
LINK = link
$(EXE) :  $(OBJS) $(PTCLIBS)
  @echo Start at `date`
  @echo PROTOOL_SRC = $(PROTOOL_SRC)
        @echo PROTOOL_SYS = $(PROTOOL_SYS)
#Executable applications compiled using WinMain() instead of main() should set the subsystem to windows instead of console.
  $(LINK) /subsystem:console -out:$(EXE) /debug:none /machine:amd64 @<<longline.list
$(OBJS) $(PTCLIBS) $(LIBS)
  @echo Finished at `date`
  del $(OBJS)
# Dll target
dll: $(EXE_DLL)
$(EXE_DLL) :  $(OBJS) $(PTCLIBS_DLL)
  $(LINK) /subsystem:console -out:$(EXE_DLL) /debug:none /machine:amd64 /dll @<<longline.list
$(OBJS) $(PTCLIBS_DLL) $(LIBS)
  del $(OBJS)
# OBJECT DEPENDENCIES
PATH_SOURCE = C:\TOOLKI~1\SIMPLE~1\SIMPLE~1\DFT\MAKE_I~1
simple_async.obj: $(PATH_SOURCE)/simple_async.c
  $(CC) $(CFLAGS) $(PATH_SOURCE)/simple_async.c
PROTK_INST = $(PROTOOL_SRC)/protk_appls/pt_install_test/pt_install_src
PROTK_UTILS = $(PROTOOL_SRC)/protk_appls/pt_examples/pt_utils
TestError.obj: $(PROTK_UTILS)/TestError.c
  $(CC) $(CFLAGS) $(PROTK_UTILS)/TestError.c
UtilString.obj: $(PROTK_UTILS)/UtilString.c
  $(CC) $(CFLAGS) $(PROTK_UTILS)/UtilString.c
clean :
  del $(OBJS)
  del $(EXE)
  nmake -f $(MAKEFILENAME)
clean_dll :
  del $(OBJS)
  del $(EXE_DLL)
  nmake -f $(MAKEFILENAME) dll
Parthiban Kannan
TomasLoun
(To:PARTHIBAN_K)
You have to check the linker problems - maybe some path is not set correctly or some file is missing...
I just simply created following .bat file for compilation in the make files folder (creoinstaldir)/protoolkit/x86e_win64/obj
call "C:\Program Files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x86_amd64
"C:\Program Files\Microsoft Visual Studio 10.0\VC\bin\nmake" /f make_simple_async
pause
and when I run it, it is compiled without problems. I have still 32 bit machine...
This is the output from the compilation I expected you will send me:
Setting environment for using Microsoft Visual Studio 2010 x64 cross tools.
Microsoft (R) Program Maintenance Utility Version 10.00.30319.01
Copyright (C) Microsoft Corporation.  All rights reserved.
        cl -c -GS -fp:precise -D_WSTDIO_DEFINED  -I.  -I../../../protoolkit/prot
k_appls/includes -I../../../protoolkit/includes  -I../../../protoolkit/includes
-I../../../protoolkit/protk_appls//includes -DPRO_MACHINE=36 -DPRO_OS=4 ../../.
./protoolkit/protk_appls//pt_simple_async/pt_sasync_src/pt_sasync_src.c
Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
pt_sasync_src.c
./protoolkit/protk_appls/pt_examples/pt_utils/pt_utils.c
pt_utils.c
Start at `date`
PROTOOL_SRC = ../../../protoolkit
PROTOOL_SYS = ../../../protoolkit/x86e_win64
        link -out:pt_simple_async.exe /subsystem:console /debug:none /machine:am
d64 pt_sasync_src.obj pt_utils.obj ../../../protoolkit/x86e_win64/obj/protoolkit
.lib libcmt.lib kernel32.lib user32.lib wsock32.lib advapi32.lib mpr.lib winspoo
.lib
Microsoft (R) Incremental Linker Version 10.00.40219.01
   Creating library pt_simple_async.lib and object pt_simple_async.exp
Finished at `date`
        del pt_sasync_src.obj pt_utils.obj
Press any key to continue . . .
Parthiban Kannan
