URL Blank when "Expand browser on startup" turned Off
CADQueen
After setting the browser to not expand during startup (File > Options > Window Settings > uncheck "Expand the browser during startup")
when clicking on the "Working directory" shortcut in the Common Folders section, the URL (a.k.a bread crumbs, path) appears blank.
If you click on a folder in the working directory, the path become filled out.
The machine is running:
  • Creo 2.0 M100
  • Windows NT 6.1 7601
  • Firefox 30
Is this an SPR? Is it dependent on the browser that is used? Any feedback is appreciated!
CADQueen
(To:CADQueen)
Since no one else has seen this before I contacted techincal support. SPR 2226932 has been logged for this issue.
CADQueen
(To:CADQueen)
