Unable to open STP files
LA_8721066
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
See pictures and log when importing an STP file. We have already updated grpahics drivers to latest release
Here are the errors that I faced
The trace creation timestamp is: Fri Dec 15 10:02:35 23
The executable build timestamp is: Thu Feb 04 00:03:18 21
The datecode is: 2020354
The pro machine type is: x86e_win64
The process ID is: 11188
The traceback type is : CRASH
The logger exit status is: 00003
The Trail is: trail.txt.51
The release is: 6.0
The product version is: 6.0.6.0
The product title is: Creo Parametric
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 11100.
Main Thread 11100
0x00007FF68C074086 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a180b90, 0x1a188248, 0x0, 0x0 )
0x00007FF6880845A4 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x5d0cd1a8, 0x0, 0x1a188248, 0xffffffff )
0x00007FF68BEFFD96 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x0, 0x7, 0x8911cd20, 0x0 )
0x00007FF68BF02C34 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a187950, 0x7, 0x1a188248, 0x64 )
0x00007FF68BF02720 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a187950, 0x1a187760, 0x1a18f1a8, 0x0 )
0x00007FF68BEC9D19 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x0, 0xffffffff, 0x0, 0x0 )
0x00007FF68BEFFB97 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x0, 0x7, 0x8911cd20, 0x0 )
0x00007FF68BF02C34 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a18e3f0, 0x7, 0x1a18ece8, 0x0 )
0x00007FF68BF02720 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a18e3f0, 0x1a18e200, 0x1a195c48, 0x0 )
0x00007FF68BF02C34 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a194e90, 0x7, 0x1a195788, 0x0 )
0x00007FF68BF02720 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a194e90, 0x1a194ca0, 0x1a19c6e8, 0x0 )
0x00007FF68BF02C34 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a19b930, 0x7, 0x1a19c228, 0x0 )
0x00007FF68BF02720 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a19b930, 0x1a19b740, 0x1a1a3188, 0x0 )
0x00007FF68BF02C34 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a1a23d0, 0x7, 0x1a1a2cc8, 0x0 )
0x00007FF68BF02720 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a1a23d0, 0x1a1a21e0, 0x1a1a9c28, 0x0 )
0x00007FF68BF02C34 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a1a8e70, 0x7, 0x1a1a9768, 0x0 )
0x00007FF68BF02720 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a1a8e70, 0x1a1a8c80, 0x1a1ab880, 0x0 )
0x00007FF68BEC9D19 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1, 0xffffffff, 0x0, 0x0 )
0x00007FF68BEFFB97 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a1ae200, 0x7, 0x8911cd20, 0x0 )
0x00007FF68912172C NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x0, 0x1a1ae200, 0x46979968, 0x3e77ec88 )
0x00007FF6891E0608 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x46979968, 0x1, 0x21b, 0x0 )
0x00007FF6890A400A NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x0, 0x2, 0x1, 0x1 )
0x00007FF6890A4FE6 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1, 0xffffffff, 0x1a1adb7c, 0x2 )
0x00007FF68908F3E3 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x35a75844, 0x35a75434, 0x0, 0x84b37a20 )
0x00007FF68909069B NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x35a75428, 0x0, 0x0, 0x1a1aed30 )
0x00007FF68909010F NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x0, 0x0, 0x800004, 0x0 )
0x00007FF684B14141 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x800004, 0x62cbbfc0, 0x62cbbe98, 0x360b9638 )
0x00007FFD62C47937 NULL (NULL:0) (libui_sh:0x00007FFD629D0000) ( 0x1, 0x203b51, 0x35a99050, 0x800004 )
0x00007FFD62B47DEA NULL (NULL:0) (libui_sh:0x00007FFD629D0000) ( 0x360e5418, 0x0, 0x800004, 0x8a60bede )
0x00007FF689E0037A NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a1aef80, 0x0, 0x0, 0x35ddccd8 )
0x00007FF689DFB329 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1a1af240, 0x1a1af290, 0x35ddcc90, 0xffffffff )
0x00007FF68A602272 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x0, 0x35ddcc90, 0x35ddccd8, 0x0 )
0x00007FF68A60299E NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x0, 0x0, 0x24, 0x0 )
0x00007FF68A60DE57 NULL (NULL:0) (xtop:0x00007FF683C80000) ( 0x1, 0xffffffff, 0x1a1af530, 0x8fb420a8 )
0x00007FF68A607674 NULL (NULL:0) (xtop:0x00007FF683
upload STP file if it is possible (pack it into zip file).
Do simple test:
  • add  graphics win32_gdi option at the end of config.pro file temporarily
  • start Creo and import STP file
Martin Hanák
Most likely there is something corrupted in the STP file.
One workaround that sometimes helps is to open the STP file in another CAD package, then re-save it. Creo tends to be very unforgiving for bad geometry, but sometimes other CAD packages can accept less than ideal geometry.
Your best bet though is to get a new STP file from the creator, and if that still doesn't work, try another neutral file format.
