I have old date M010 of Pro/Engineer WF5.0. Now I need to to install new date code WF5.0 M060 .
Do I need to Uninstall my previous pro/E?
If No, Is there any patch file to update from date M010 to M060?
Please let me know the procedure.
Amit
I haven't seen any patches. Just want to let you know that M070 is available if your gonna be re-installing.
Amit,
I always make a new installation. I think this way is the most reliable one.
It is possible to make an update, that means to install M060 into M010 install dir, but I can't recommend this procedure.
Martin
