When saving the assembly, it stays in the progress of model check and does not respond for a long ti
晓宋_10170248
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
When saving the assembly, it stays in the progress of the model check and does not respond for a long time. After changing the digital model to save, it is still the same.
Translated the text from Simplified Chinese to English using google translate. By community moderation.
Subject: 另存装配时,停留在model check进度中,长时间不响应。
Body: 另存装配时,停留在model check进度中,长时间不响应,换过数模保存,依然如此。
Try disabling modelcheck to see if that is really the problem.
If it is, check access to the settings files and output directories, or the settings themselves.
If it is still slow to save without Modelcheck, try disconnected from Windchill.
If that solves it, clear your Windchill cache, but take care to upload your work first.
