Which parent batch file called another batch file?
gchampoux
I have a particular utility batch file (A) that is called from several other "parent" batch files (B,C,D).
I would like batch file A to determine which parent (B-D) it was called from.
Is this possible without passing an argument?
Gerry
RandyJones
(To:gchampoux)
> (B,C,D).
You could also set an environment variable in parent and check the value of it.
> Gerry
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
My goal is to avoid editing the parent batch files.
Gerry
In Reply to Randy Jones:
