config.pro options - spreadsheet
MikeLockwood
22-Sapphire I
Has anyone put all Creo 3.0 config.pro options in Excel?  The PDF that lists all (creo3_m060_parametric_configoptions.pdf) is 162 pages long.
We're methodically going thru our Creo Elements Pro/WF5 config.pro and config.sup files, updating for the latest Creo 3.0.
It would seem that pretty much everyone has these needs for this:
- Consider each option and it's default value.  Decide if the default is ok.  If not, change it in your standard config. Decide whether .sup or .pro.
- Add comments for each decision.
PTC supplies all needed into as a PDF; would seem that pretty much everyone would need to convert to Excel somehow.
thanks
David Haigh‌ has put together something like this for Creo 2.0 a few years ago.
I've got no idea where i found the file back then so i just added it to the attachment.
TomU
(To:MikeLockwood)
Proesite.com has a full listing of all Creo 3 options.  Unfortunately it doesn't list the default values.  I imagine it would very easy to cut and paste this into Excel.
danderson
11-Garnet
(To:TomU)
Tom,
The default value and options for each setting are listed when you click on the links.
The default value has a * next to it and some say default.
Hidden config options do not have a default value.
Don Anderson
David_M
(To:TomU)
Thanks for this link. The site just showed me REFIT_FOR_XSEC_OR_ZONE which sounds great if setting it to "no" will work.
TomU
(To:MikeLockwood)
I just took the PDF for M060 and converted it to Excel.  Use at your own risk.
There is a file that appears to list many, many config.pro options installed with Creo Parametric.  The file is <PATH_TO_CREO>\Common Files\text\config.cdb.  It is a text file.  It doesn't appear to list hidden config options.  I was able to open it in MS Word and do some text search/replace and paste it into an Excel Spreadsheet.
