Hi everyone,
I want to create a mapkey which will ask for input only once while using and after that it will use that input for rest Of drawing.
For example, I want to create a mapkey which while using in drawing will ask once only Which Model You want to select(By using Pause command for mapkey) And afterwards for rest it will use that model for rest of modeling I.e. whenever I will use that mapkey it will Automatically set previously selected Model. If it is done It will be helpful for me to share this config file for customer who can then easily select their most used view According to drawing.
Thanxxx In advance For your Reply
This is not possible without the use of external scripting or one of the APIs. Mapkeys only record what you do and then allow you to repeat the exact sequence again. There are no previsions for storing information in a variable.
