hi
I am getting a model save error while i am saving the simulate model. any solutions
I found a similar case in our internal database: The model had been sent to PTC Technical Support for investigation and R&D found out that the model had some data corruption, that needed to be fixed in the model file.
Unfortunately the cause for the data corruption never could be found.
So I recommend to either:
The error will come up if you use "SAVE AS" in the Simulation environment.
To find out what case the error will be almost impossible.
Use a older version like the other guys recommended.
Take care!
Bogdan
