Thanks for the great suggestion, David. I'll have to keep that one in mind for future problems.
It turns out I had pre-selection highlighting turned on (and I could see the line) and my coworker did not (and he didn't see the line). It's a pretty simple fix to toggle it on.
Thanks again!
Best regards,
Janet Grove
In Reply to David Haigh:
Try setting the config.pro graphics to
graphics win32_gdi
If that fixes the problem then it's a graphics card issue.
David Haigh
