Hey all - looking for help in regarding exporting pipes via a stp format. You would think they would be handled similar to cables with a toggle to "export pipe surfaces" in the stp export options menu.
I have followed all of PTC's published guidance and understand that I need to create a pipe solid, but cannot get CREO 4 to create the solid.
I select the pipe segments that I want converted and then select make. This is where I get confused....I am assuming that their should be new solid parts created either in the tree or in my working directory.
What am I missing? Thanks in advance.
This seems strange, did you try the same in new session of Creo? Is there any warning?
You may contact PTC Tech Support for this issue, if in active maintenance.
It was due to incorrect values in link stock for piping.
